electronic issues on 89
Old Aug 10, 2006 | 03:16 PM
sledog's Avatar
Default electronic issues on 89
Has anyone ever had their heater/air condioner, lights on guages, and abs motor all turn on while the key is out of the car (as in ignition switch is in the off position)? The first thing I thought was that maybe the ignition switch on the car has failed, but after disconecting the wires (blue and black molex connectors) from the steering colum, the problem is still there. Anyone with some input would be greatly apreciated.
Old Aug 11, 2006 | 09:32 AM
Default RE: electronic issues on 89
Only thing I can see in the wiring diagram is the "Module Relay" being stuck on. It is the only thing common to all those occurances. If it happens again, pull your "Brake" fuse, 10 or 15 amp, out and see if it quits. [8D]
bradsky
Jun 9, 2010 02:49 PM
bertsbassbox
Dec 26, 2009 07:44 PM
AntsSilverC5
Sep 20, 2007 08:36 PM
imb1987
Feb 22, 2006 06:51 PM
danielkeith
Jan 10, 2006 03:04 AM
