Electronic problem
Old May 26, 2017 | 04:55 PM
Shirleybird's Avatar
Default Electronic problem
My alternator burnt up and I replaced it. I was driving it today when it started to run rough,the ac freaked and quit as the charge went to 16 amps. I pulled over pulled the plug and drove her home. I have looked for the problem but no luck. Anyone else had this problem? Any suggestions as to where to look?
Old May 27, 2017 | 01:28 PM
First have the place you got the new alternator at test it. Was it a new or rebuilt alternator?
Was it 16 amps or volts?
When you said old alternator "burned up", what were the symptoms?
Did the current/voltage go back to normal when you disconnected the A/C?
Did you try reconnecting the A/C to see if the problem returned?
If not the alternator then I'd suspect the A/C compressor clutch. Might check the resistance of the clutch and compare w/ a good one.
