Engine overheat
I have change the thermostat water pump and the engine still gets hot and overheats I've run out of options in my head to figure out what is wrong other than Maybe I may need to flush the engine possibly due to a blockage does anyone have any ideas does not matter if the engines at running temperature idling or driving temperature it will continue to overheat
Double Post? Im new here, but maybe nobody can answer your question because it is very vague. You will need to let somebody know 1. When it overheats. Example, driving 55 down the highway. 2. How long it runs before it starts getting hot. 3. There are several other factors that need to be described so someone can help you out.
Again. New here and not trying to be a jerk, but trying to figure out if both of us need to find a different forum!
