fuel injectors
Old Oct 6, 2007 | 11:48 AM
fun4rx's Avatar
Default fuel injectors
I returned from another great time at Funfest '07 with some new parts
and ideas for my 89 coupe. Went to Gordon's seminar and he always
talks about checking fuel injectors. So on the way home stopped at
Sears in Terre Haute and bought an Ohm meter and when I got
home checked my fuel injectors. 5 read 16.9 which is great but three read
8 to 12. So now with this knowledge, how easy is it to replace the
fuel injectors? I'm not much of a mechanic but I did buy this car to be
my new hobby. Gordon also recommended Lucas injectors but I can't
find any listing for these, he did say the kit from Mid-America which uses
Accel's were fine.
I'm getting 20-25miles/gallon and car ran great on road trip around Illlinois
but I guess I'm running on borrowed time if 3 injectors are going bad.
Old Oct 6, 2007 | 12:09 PM
rshiver's Avatar
Default RE: fuel injectors
Hi Fun...It's really not that hard, but It's not something you're going to do in a couple of hours. The plenum has to come off, maybe even the runners. You'll need new gaskets for the runners.
I need to replace my injectors too, but when I do I'm going to replace the EGR valve and temp sensor under the plenum, maybe even the fuel pressure regulator, while I have everything off
Old Oct 6, 2007 | 07:53 PM
ORIGINAL: fun4rx
Accel's were fine.
Pulling injectors ain't tough. BUT, tie some string or fishing line to a paper clip, and hook it to each injector retainer clip, BEFORE pullingthe clip. If the clip goes ballistic, you could lose it.
I don't know if I'd worry too much about a few extra ohms at the injectors. I think vacuum leaks are more a problem with TPI's than anything else - I'm sure GK probably mentioned this, didn't he?
Did you happen to record his stuff?
Old Oct 6, 2007 | 07:59 PM
Mating surfaces must be IMMACULATE at re-assembly. Like where the injectors O-ring seats in the intake. A speck of grit will allow a vacuum leak, and that's a tune-killer. As are gasket surfaces...
Old Oct 8, 2007 | 05:05 PM
fun4rx's Avatar
No I didnt record Gordon's talk but I sat in on 2 this year and 1 last year,
I've thought about signing up for his week-end class. Has anyone been to
his class?
How do you check for vacuum leaks?
Old Oct 8, 2007 | 05:14 PM
ORIGINAL: fun4rx
his class?
It's a bear to find leaks. One method is with a propane hand-held. Attach a 2 foot length to the nozzle, crank up the idle till it's steady idle, then feed the propane into areas where components meet - throttle body to intake, intake runners, etc. An idle speed increase means a leak. They're VERY HARD to find.
If you do have a leak, there's NO reason to do ANY mods at all till they're tight.
You got a lopin' idle? If not, you're probably OK.
Old Oct 8, 2007 | 05:55 PM
One easier method is use a piece of 3/8 fuel line about 3' long. Put one side to your ear and the other to listen around engine for a hissing. The hose isolates the area just where you are listening. Another way is to use carb spray, but be very sparing with it. If you find a leak, the spray will change the idle, smooth it out.
fun4rx's Avatar
propane, like in a gas grill or hand torch?, Does the propane get sucked
in and rev the engine?
Old Oct 8, 2007 | 06:10 PM
ORIGINAL: fun4rx
Exactly. And youcould use a grill propane tank just as readily as a hand-held torch. Ya' just gotta' get some rubber line long enough so you can put the tank on the ground. You won't be able to hold it up long enough to do a complete check. Just barely open too.
Does your idle hold steady?
Old Oct 8, 2007 | 06:20 PM
fun4rx's Avatar
yes, my idle is pretty steady, if I sit at a light for a long while it sometimes
drops from 8 to 7 but it doesnt lope.
