fuel injectors
Old Oct 10, 2007 | 06:30 PM
  #31
Default RE: fuel injectors
ORIGINAL: Ric
Thanks rshiver I just replaced the fuel pump last week because it only was getting to 35 lbs.
35 lbs is the normal operating pressure for L98's. If it is @ 35, unplug vacuum hose to the pressure regulator and see if pressure rises 3 - 4 lbs. If so, the pump is probably ok.
Old Oct 10, 2007 | 06:33 PM
  #32
ORIGINAL: cwb
EDIT: I'm thinkin' here - (see the smoke) -
Is the regulator mechanically controlled? Or is it electrical, and it opens up and lets the pressure off when you kill the motor?
That still doesn't explain why you're supposed to bleed off pressure.................................
The pressure is controlled by an engineered compression spring and engine vacuum. The vacuum overcomes the tension of the spring via a diaphragm, hence the regulator leakage. You can test that by just pulling vacuum line from regulator to see if fuel is present.
Old Oct 12, 2007 | 11:12 PM
  #33
ORIGINAL: mech259
ORIGINAL: cwb
Gotcha[sm=interesting.gif].
Not'cher first day, huh?
red85
Nov 23, 2006 11:39 PM
mercedes84black
Apr 22, 2006 11:03 AM
nosactivated
Apr 19, 2006 09:59 AM
KillaCam
Feb 25, 2006 10:47 AM
KillaCam
Feb 20, 2006 09:43 AM
