Fuel pressure regulator noise?
Old Mar 17, 2008 | 01:31 PM
atcdork's Avatar
Default Fuel pressure regulator noise?
Hi,
I have an 86 coupe, steel heads, automatic.
I've got this tapping noise coming from the engine that's loud enough to hear inside the car. At first I thought it was a lifter of something, but I took a stethscope to it and it seems like it's coming from the fuel pressure regulator. The frequency of the tapping increases with engine RPM.
I've had other cars with fuel injection, so I'm familiar with the tapping sound injectors make. This is the same, only a lot louder.
So my question: can a fuel pressure regulator make that much noise? It's an aftermarket FPR that the previous owner installed. I did check the pressure a while back and adjusted it to stock setting (I forgot offhand what the psi was). I also have a new fuel pump and fuel filter.
Thanks,
Ed
Old Mar 17, 2008 | 08:56 PM
Default RE: Fuel pressure regulator noise?
1st, check your vacuum source and make sure it is steady. if so, the the regulator has been known to do that.
Curious George
Nov 19, 2006 11:54 AM
dpop24
Oct 30, 2006 11:59 PM
bobbiebello
Sep 23, 2006 06:57 AM
bobbiebello
Aug 6, 2006 11:20 PM
tiggerrick
Mar 18, 2006 03:29 AM
