Fuel pressure regulator valve
Old Mar 5, 2006 | 05:11 PM
tiggerrick's Avatar
Default Fuel pressure regulator valve
I am having trouble with smooth starts on a warm engine now that I changed the spark plugs and have been checking EVERYTHING I can think of. I know the car is running rich because I checked the NEW plugs and they have lots of black residue. Have changed the fuel filter, checked vaccum hoses, measured O2 sensor output, checked for codes, etc.
Anyhow, I unplugged the fuel pressure regulator valve from the suction hose and noticed that now and then a drop of fuel spits out. Is this normal, or is the regulator faulty? Is there any way to check it before I replace it?
Old Mar 5, 2006 | 10:46 PM
crvttbass's Avatar
Default RE: Fuel pressure regulator valve
if your getting liquid gas out of the port where the vacume line connects you are in need of a new regulator. I suggest getting an adjustable regulator. That way you can always keep your fuel presssure right where you want it.
Old Mar 18, 2006 | 03:29 AM
tiggerrick's Avatar
I replaced it, it took less than 10 minutes, and the car now runs like a champ. Thank you for your advice.
atcdork
Mar 17, 2008 08:56 PM
Curious George
Nov 19, 2006 11:54 AM
dpop24
Oct 30, 2006 11:59 PM
bobbiebello
Sep 23, 2006 06:57 AM
bobbiebello
Aug 6, 2006 11:20 PM
