headlights are next
Old Oct 5, 2007 | 08:53 PM
  #11
rshiver's Avatar
Default RE: headlights are next
[sm=funnypostabove.gif]
Old Oct 5, 2007 | 09:14 PM
  #12
racerrick's Avatar
my driveway is outside my bedroom window.quiet place to live
Old Oct 7, 2007 | 04:08 PM
  #13
racerrick's Avatar
new controller on the way will keep you updated
Old Oct 18, 2007 | 08:10 PM
  #14
racerrick's Avatar
update inatallrd new controller headlights on no flip turn off and back on flip. over and over in a row it works fine let it set 45 sec will not flip on first try but 2 nd its fine.so im glad they flip but it would be nice if it did it the first time.
Old Oct 18, 2007 | 08:31 PM
  #15
rshiver's Avatar
ORIGINAL: racerrick
Hi Rick, I take it that both are opening, when they do open. On the 5 wire connector you have, yellow (A), red (B), white (C), black (D), red (E).The next time theydon'topen, check and see if (A)has 12vwith the headlight switch on . Then check and see if (C)has 12vwith the headlight switch off. If you don't, you could have a badheadlight switch too.
Old Oct 18, 2007 | 08:49 PM
  #16
racerrick's Avatar
missed detail i have 12v at both feed wires. the switch did get hard to move so i took it apart cleaned it and put it back togther.might be a cheap fix if it is it
Old Oct 18, 2007 | 09:03 PM
  #17
ORIGINAL: racerrick
What can be happ'nin' on the second switchin', that ain't happ'nin on the first switchin'???
And does it take 2 switchin's to close the assembly?
Old Oct 18, 2007 | 09:10 PM
  #18
racerrick's Avatar
they light up and no flip the first time. 2nd time the work fine not the same speed but the both flip to lock and close perfect on the first time
Old Oct 18, 2007 | 09:11 PM
  #19
rshiver's Avatar
"B" & "E" are the feed wires and should have 12v all the time.
"A" should have 12v, only with the headlight switch on, it shouldn't have 12v with the switch off.
Just clarifying that, in case we're misunderstanding each other.
Old Oct 18, 2007 | 09:13 PM
  #20
ORIGINAL: racerrick
And both are doin' the same trick exactly the same way every time???
