heat
Sooo, I just got the vette back on the road after it winter nap. When I put it into hibernation the heat worked and the car ran at about 185 degrres. Day one back on the road, the heat dose'nt work and it's running about 200 degrees. What do ya think????
Make sure your coolant is full first. If it is then feel your radiator hoses and see if they're close to the same temp. If not you may need a new thermostat. Check those two things before going any farther. They're the easiest to check.
