Help!!
Old Oct 14, 2007 | 04:54 PM
  #11
95trplblkandtan's Avatar
Default RE: Help!!
alright, the car is cured!! thank god. It was out of fluid, so i put some more in fluid in it and waited a while and the clutch was working fine... now i just need to check for leaks and go from there... thanks for all the input guys.
Old Oct 14, 2007 | 05:01 PM
  #12
rshiver's Avatar
Default RE: Help!!
That's a good deal, glad it worked out for ya.
Old Oct 14, 2007 | 07:08 PM
  #13
Default RE: Help!!
ORIGINAL: 95trplblkandtan
How many miles you got here?
A leak might be a good thing, cause like brakes, when the brake fluid gets low, it's cause the brake pads are nearin' replacement time, and the caliper pistons are goin' in further to take the place of the worn disc thickness. If the clutch disc is gettin' thin, the fluid level will drop much the same way as the brake pedal.
spanky01
Jul 23, 2007 02:53 PM
mjrock62
Jun 8, 2007 07:07 AM
74vetguy
May 18, 2007 06:23 PM
aceosner1
May 16, 2006 09:23 AM
sixspeed042
Oct 10, 2005 02:00 PM
