help C4 hood id? what year?
Old Nov 5, 2008 | 01:10 PM
jmartinlawn's Avatar
Default help C4 hood id? what year?
i have a c4 hood for sale but i dont know what year model it is off of. any help?
Old Nov 6, 2008 | 10:28 AM
beauchampgl's Avatar
Default RE: help C4 hood id? what year?
Although I can't give you an exact year, I can narrow it down for you. 84-90 have two vertical vents behind the wheel wells. They look like fish gills. 91-94 have four vents with strakes going back from the vent opening. 95-96 are similar but the strakes aren't as long. Hope this helps.
Old Nov 6, 2008 | 11:25 PM
toms69's Avatar
Correct me if I am wrong, but the vents are not part of the hood. I have an 84 and the vents are below the hood in a separate panel. Is the 84 hood different from the others? I have wondered about this myself.
Old Nov 6, 2008 | 11:30 PM
toms69's Avatar
Default 84 Dash Main Cluster
Can anyone tell me where to buy the bulbs that go in the dash cluster? The side of my cluster that houses the tach is dark, so I took it apart and found two of the larger bulbs to be bad. They were not blackened, but I used a strong magnifying glass and could see the break in the element. I think 2 new bulbs will solve this problem. Any help will be appreciated. Thanks.
Old Nov 6, 2008 | 11:32 PM
toms69's Avatar
Default RE: 84 Dash Main Cluster
Sorry about my previous post. I should have started a new topic. I'm learning.
Old Nov 7, 2008 | 10:02 AM
You are correct. the vents are separate. Don't know what I was thinking. Silly me. The l parking/ fog light openings may be different. Or, you could check with the Chevy dealer near you.
Old Nov 11, 2008 | 01:15 PM
LeesVette's Avatar
ORIGINAL: beauchampgl
The parking/fog lights are not part of the hood either.
Old Nov 11, 2008 | 08:18 PM
partsman41's Avatar
The '84 hood is unique. It has the internal passages that deliver air to the openings in the crossfire air cleaner housing. Then (I think) in '86 the hood support changed from the somewhat troublesome mechanical wonder to hydraulic struts,which may have caused differences in the built in fasteners. That's all I know!
Ron
blantz
Apr 30, 2009 01:32 PM
jmartinlawn
Nov 5, 2008 01:08 PM
9TBLKC4
Aug 28, 2008 09:06 PM
taz7nads
Sep 7, 2006 11:37 PM
nashmaan
May 26, 2006 02:29 PM
