HELP PLEASE...My Vette runs like crap!!
Old Feb 28, 2008 | 11:15 PM
  #11
Default RE: HELP PLEASE...My Vette runs like crap!!
Before ya' spend cash on a new sensor, see if ya' got voltage comin' in TO it.
If you got no voltage comin' TO it, DON'T buy a new sensor yet.
If you got power To the sensor, see next if you can ground 12 v through the sensor's other (ground) wire. If ya' can't, that MIGHT be the short circuit, stoppin' a good o/t sensor from workin'...
Old Feb 29, 2008 | 06:42 AM
  #12
The sensor does NOT have 12v to it. It is a 5v reference from PCM and it is a 3 wire sensor, meaning it has a 5v reference, a ground and signal to PCM to measure oil temp, and after a little research, the oil temp code does not affect driveabilty. It is used to measure oil life on the oil life monitor system. How it works is the oil temp average will be higher on deteriorated oil than on fresh oil and when the oil temp average reaches a certain calculated point, the code can set. If the reset procedure does not clear the code, then the sensor might be at fault.
Old Feb 29, 2008 | 09:48 PM
  #13
ZR1clone's Avatar
I just had my oil changed and reset the light on the dash. Plus my Change Oil light came on about 500 miles before the scheduled mileage. As a note my oil temp gauge and my engine temp gauge do not work. I also have only two lights that are faulty on my dash that I know of. I have a "CHECK GAUGES"light and a SEAT BELT light. So................................................ .If the oil temp sensor does not affect driveability then..... it must be the EGR and the dirty throttle body and maybe some other dirty stuff like the plenum or .....................NOW WHAT?
Old Feb 29, 2008 | 09:54 PM
  #14
It's going to be hard to say. EGR normally affects idle, not under throttle. I would need to know fuel pressure readings, try unplugging MAF to see if performance improves. Try unplugging coolant sensor just to see if that improves it. Other than that, I would have to see scan tool readings, try an injector balance test, so forth. What shape are your spark plugs?
Old Feb 29, 2008 | 11:30 PM
  #15
ZR1clone's Avatar
Hopefully I will get a chance to do that plug check tomorrow. I was thinking of pulling the radiator and cleanig it and under the plenum. Also the TB and plenum if able. Thanks-Kev
Old Mar 1, 2008 | 06:18 PM
  #16
cwyates4's Avatar
Hey mech259,
Not to hijack, but I just noticed that you live in lumberton. Im about 45 minutes north of you in Jasper. Do you do mechanic work down there? If so maybe I'll bring you my vette when something goes wrong, or maybe to upgrade some more. Its got a forged 383 stroker with aluminum fastburn heads and miniram intake, just need some spray now .
Old Mar 1, 2008 | 06:43 PM
  #17
ORIGINAL: mech259
Who told him it does have 12 V TO it???
Old Mar 2, 2008 | 08:16 PM
  #18
LeesVette's Avatar
ORIGINAL: cwb
ORIGINAL: mech259
Kind of sounded like you did in your previous post but who knows, I am an idiot.
Old Mar 3, 2008 | 01:24 AM
  #19
Yeah - it KINDA' did... But yours truly did NOT say look for 12 volts comin' in. Your truly said to check for VOLTAGE comin' in - ANY voltage.
Yours truly DID say to see if the ground wire at the sensor would ground out a 12 volt current. I said 12 V, because that's all he's gonna' find layin' around, for testin' purposes of a good ground.
ORIGINAL: cwb
No problem tho' that someone ELSE thought I meant to look for 12 V comin' in.
We all know what they say about assumptions, and what it makes the 'assumer' look like...
Now, where were we?
Old Mar 3, 2008 | 05:52 AM
  #20
Yes, I have an ASE certified shop in Beaumont on west College st.
