High Idle
Old Aug 9, 2007 | 01:19 AM
dpop24's Avatar
Default High Idle
My 91 recently started idling very high. It used to hang around 1000 RPM but just this past week it idles at 1500 when cold and between 2000-2500 after it warms up. I know this is too high, but is there an easy fix for a novice mechanic or do I need a pro to take a look? The manual says to hold it at 2000 RPMs for 2 minutes to clear the oxygen sensors. This was the first thing I tried and it didn't work.
Old Aug 9, 2007 | 12:50 PM
84corvetteC4's Avatar
Default RE: High Idle
we are goning to need more info to solve your problem, are there any codes(check engine light on) how many miles and when was the last tune up (plugs, opti cap, wires, air filter???) you need to check your timing also.
Old Aug 10, 2007 | 04:35 PM
Superdzzz's Avatar
My '87 baby idles around 750, extremely smooth even at that low rpm
I heard this is normal[sm=icon_cheers.gif]
Old Aug 11, 2007 | 12:04 AM
dpop24's Avatar
Hey guys, thanks for the input. There are no codes except the annoying "sys" that has flashed ever since I put in a new aftermarket stereo.
I have about 134,000 miles and haven't done a tune up since I bought it last year at 130K. I'm guessing you guys are going to tell me that I need to give her a tune up.....
I will do that in the next week or so.... what is an "opti cap"?
Old Aug 11, 2007 | 06:39 AM
Sounds like idle control motor. Only way to be sure is to see what IAC counts are on a scan tool. If you replace idle control, be sure and disconnect battery for a couple of minutes to reset idle. Then drive it to let it relearn idle.
Old Aug 18, 2007 | 10:53 PM
from what you saying it sounds like you need to take it to a reputable mech. and have him take a look at it(but buying parts to an un-diag. problem is not the answer)unless your comfy doing all of the above your self^^^
Old Aug 19, 2007 | 07:43 PM
mrt347's Avatar
It's not a vette, but my year old focus started running high at idle. Took it and they told me the throttle plate and cable were loose. Perhaps this is also a possibility.
hereitis1967
Jul 23, 2012 07:33 PM
95trplblkandtan
Aug 17, 2008 10:33 PM
acedraven
Aug 19, 2007 11:00 PM
deltb
Corvette C6 Z06
28
Nov 24, 2005 02:07 AM
HillSmith
Sep 6, 2005 11:53 PM
