HIGH NO on Smog
Old Oct 9, 2006 | 03:21 PM
mikenann's Avatar
Default HIGH NO on Smog
Hello Everyone
I got a 1987 that is failing California Smog. It is giving me a high NO (1558) reading at 15mph but a clean NO reading of 308 at the 25 mph measurment.
Any ideas?
Before I break down and take it to the DEALER!!!!!
Tanks
Mike
Old Oct 9, 2006 | 05:31 PM
Default RE: HIGH NO on Smog
Can you lean out your idle setting?
Old Oct 9, 2006 | 08:39 PM
All2kool's Avatar
Catalytic Converter I'm sure.
Old Oct 10, 2006 | 09:49 AM
Check your smog pump diverter valve, make sure it is opening up downstream air under throttle. High NO readings mean unburnt fuel in downstream exhaust. Take off hose on check valve on exhaust to see if air is pumping under throttle, NOT at idle. If you have air at idle or not under throttle you have either a bad valve or the switch is bad on the valve, Also, check your vacuum source to valve. [8D]
JSGarner
Apr 18, 2007 01:23 AM
89rdstr
Apr 8, 2007 11:37 PM
ppwertime
Nov 20, 2006 09:16 AM
dpeterson1
Oct 15, 2006 11:39 AM
abc
Oct 3, 2006 03:21 PM
