Oil leak
Old Oct 9, 2006 | 04:14 PM
LT4Dave's Avatar
Default Oil leak
Recently aquired '96 LT4. Has a good oil leak from front of engine. I can't quite see were it is coming from. Any common problems with this? Any suggestions?
Old Oct 9, 2006 | 05:28 PM
Default RE: Oil leak
If it's hard to see, I would think the first suspect is the front oil seal, behind the harmonic balancer, and mounting in the timing gear cover. Next, is the timing gear cover, gasket. If either of these is the prob, change both, the timing gear cover, gasket and the front oil seal.
If the leak is up top, intake man. gasket or valve cover gaskets, oil can sometimes cover the front of the engine, from top to bottom.
If you should need to change the intake gasket, also change the valve cover gaskets. Any time, generally,
if you disturb a gasket, change it. Now you have no doubt about that componant, no leaks.
Hope this helps.
Old Oct 10, 2006 | 02:27 PM
LT4Dave's Avatar
Thanks for the reply. Fixing that oil leak will be my winter project.
Sullyvette48
Jul 8, 2019 04:47 AM
bj11670
Feb 10, 2008 12:51 PM
santaman58
May 13, 2007 10:25 AM
89rdstr
Apr 28, 2007 03:34 PM
mazie
Oct 3, 2005 12:32 AM
