I HAVE THE 4-3 BLUES!!
Old Oct 1, 2008 | 11:06 AM
CARTER's Avatar
Default I HAVE THE 4-3 BLUES!!
I have a 4-3 trans in my 86. Just after I had my clutch replaced. 1 week later, the o/d started to run in and out of gear. upand down up and down. Then it stops all together. I reset the computer, it tried to shift a few times, same thing then it stops trying.
I can control the dash light with the button on the shifter, but trans dose not move.
I checked the relay on the firewall. no problem there.
I replaced the ECM. No fix there.
I will have it back on the lift on the shop today. Any ideas of what to look for? I have the haynes manuel, not much in there about this trans. It is vague at best.
Flustered.
Old Oct 1, 2008 | 11:28 AM
Default RE: I HAVE THE 4-3 BLUES!!
Yes, you got that right - "vague at best". Haynes' should have a round hollow binder, so you could hang it in the 'library', tear a page, read, wipe, and flush.
I don't know what to suggest on the tranny diagnostics there...
KenHorse
Aug 10, 2007 04:00 PM
becuzitsthere
Mar 9, 2006 03:56 PM
Eagle223usa
Jul 5, 2005 12:26 PM
bRKrbcing
Jun 29, 2005 03:25 AM
