idle issue
Old May 14, 2006 | 07:42 PM
hangn7's Avatar
Default idle issue
Help, 84 crossfire, cannot get it to idle down, sometimes will die at the light, runs good except at idle, computer no help, oxy sensor ok, someone suggested maybe issues in the distribitor. Any ideas thoughts to fix would be greatly appreciated.
Old May 15, 2006 | 09:30 AM
Default RE: idle issue
Check for vacuum leaks, then check the throttle body that has the idle control motor. Motor might be stuck open, check by sticking your finger in the hole that has idle bypass air going through it and see if it idles down. Also moved your post to the C4 section.
73shark
Jul 20, 2007 10:35 PM
73shark
May 26, 2007 12:21 PM
hangn7
May 15, 2006 09:30 AM
mercedes84black
May 3, 2006 03:41 AM
rcheath
Oct 24, 2005 11:02 AM
