injector and service light issue
Old May 3, 2006 | 03:41 AM
  #11
Default RE: injector and service light issue
If your signal wire is 7v from a 5v reference, you either read your meter wrong or you have a voltage feedback from the ECM. If you read your meter right, then either the ECM is bad or there is a short to B+ (Battery) on the signal wire to the ECM. Do you have a good voltage sweep by moving throttle and watching signal voltage? My bet is you have a bad ECM if your voltage readings are right with engine idleing. [8D]
shooter71
Jun 16, 2013 08:43 AM
vettesroc
Aug 31, 2008 07:38 PM
splmagic1
Dec 24, 2006 09:01 PM
seapup0
Sep 27, 2006 02:37 AM
rcheath
Oct 24, 2005 11:02 AM
