Intake Manifold Gasket Replacemen
Old Apr 22, 2008 | 02:25 AM
85vette80821's Avatar
Default Intake Manifold Gasket Replacemen
Im going to be replacing the intake manifold gaskets this weekend as there is a coolant leak that I can see coming from above cylinders 5 and 7. I have a few questions before I take this task on. Will I be able to remove the right and left runners along with the plenum in one piece? If not, should I just replace the runner to plenum/manifold gaskets also since there are already apart? Ive seen gasket kits that include these gaskets in the kit. Since I will be removing the fuel rails and injectors, are there things I should get to replace on these parts, like o rings or c clips and such? Is there any hints or tips that you veterns can lend me before I do this project? Any information will be greatly appreciated. Thanks!!
Old Apr 22, 2008 | 10:41 PM
Default RE: Intake Manifold Gasket Replacemen
ORIGINAL: 85vette80821
No, they have to come off seperately.
Always replace gaskets, never reuse, since you will probably destroy them anyway. You will need upper and lower injector o-rings. There are a couple of hidden torx head bolts hiding under the plenum, so look carefully.
Old Apr 25, 2008 | 10:26 PM
Clean workin' space is important.
Cleaned parts, AND bolts and bolt holes is always good too. Nothin' like a bolt goin' back into a grit-free hole.
Put string or fishin' line or a bread-bag tie on your injector retainer clips. If they go ballistic on ya', it's history.
I suggest a TOTAL dry fit first, skipping tough bolts (first and last runner-to-intake (you'll see)), and no torqueing.
Put a thin grease film on gaskets, and Trans-X on injector O-rings. TPI's are terrible for intake leaks, with all the components.
gumby
Nov 12, 2011 08:21 PM
corvette84
Mar 25, 2009 06:57 PM
harleymarkt
Mar 13, 2008 10:25 PM
imb1987
Jan 25, 2006 02:57 AM
Krayon
Nov 5, 2005 09:24 PM
