key fob
well my key fob has quite working my car is a 94 model i put a new battery in it and it will work when i push the bottons but it will not set the alarm or unlock the doors when i get near, is the key fob bad or do i need to try and program the car
The Passive Keyless Entry module controls your remote access and I'm afraid your going to have to have someone with a GM Tech 2 scanner diagnose your problem, the shotgun approach to fixing this one might get very expensive. Good Luck.
I just bought a 94 and got the keyless entry trans online. I'm having the same problems. The hatch works and the doors work, but the alarm with not activate (beep) and deactivitate (beep) when I come with in 4 ft of the car. Is there somewhere where it can be turned off in the car? All I get is the lock doors, unlock doors and release the hatch. No sounds or horn. If I manually lock the doors and then reach in and unlock the doors and open and enter car the alarm will sound until the key is placed in iginition.
