A Little Help on my 1st Vette
Old Jan 10, 2007 | 01:46 PM
bugsym's Avatar
Default A Little Help on my 1st Vette
Yesterday, I picked up my first Vette, a 1989 6-speed with Z51 and sport seats. The only things that don't work are the power antenna and the drivers seat lumbar.
I've read in several posts that the antenna is a pretty common problem. I think I can hear the motor run when I turn the car off (or maybe its the fuel pump spinning down?). At any rate, is this an easy fix?
The passenger seat lumber works fine, but there's no action on the drivers seat. When I push the switch, the compressor dosen't run. I've read that the compressors have circuit breakers. Are they located in the fuse panel? Any idea which breaker it is? Is it common for the switch to fail? Is it common for the compressor to fail? I don't want to replace the compressor only to find out I had a bad switch, and vice versa. Do I need to remove the entire seat to get to this stuff?
Sorry for so many questions, but any help would be appreciated.
Thanks!
Old Jan 10, 2007 | 03:19 PM
bugsym's Avatar
Default RE: A Little Help on my 1st Vette
BTW, here's a picture. The cars behind mine are both Challenge cars. The white one is an 88 and the lettered one is an 89
[IMG]local://upfiles/4345/369DC2FA64124FC997833FE3215A9F3E.jpg[/IMG]
Old Jan 10, 2007 | 07:46 PM
mdmoore's Avatar
I have an antenna out of an 84 that I'm parting out, $35.00+7.00sh
Old Jan 11, 2007 | 12:49 AM
The antenna sometimes can be repaired by replaceing the mast assembly. If the motor runs all the time, the mast tape is broke. If you do a search on the C4 forums for antenna, I think I remember an illustrated repair for it. [8D]
cwrobin
Aug 6, 2007 11:30 PM
all84vette
Jan 16, 2007 06:29 PM
regchamp
Sep 10, 2006 01:58 AM
all84vette
Aug 29, 2006 06:18 PM
383Stroker
Jan 12, 2006 08:23 PM
