LT1 Code 33
Old Mar 17, 2008 | 08:11 AM
LeesVette's Avatar
Default LT1 Code 33
If your LT1 started running really rough. Missing badly especially at low RPM and you limped it home and got a code 33 "MAP Sensor". Would you order a new MAP sensor and try that first? I know what the FSM says but I do not have the means to test it the way the charts are laid out.
Old Mar 17, 2008 | 12:34 PM
LeesVette's Avatar
Default RE: LT1 Code 33
Anyone?
Old Mar 17, 2008 | 05:12 PM
Viscount's Avatar
I would start by checking the vacumn connections as well as the electical hook up. You have to remove the MAP to inspect the vacumn connection which I think is on the bottom of the MAP.
Don't know what a new MAP would cost, but I suggest you consider gettin it diagnosed before replacing a part that may be good? Hope it's just a loose connection or something simple?
Old Mar 17, 2008 | 08:51 PM
Lee, if you can check the voltage return (signal) and let me know what that is, assuming you have the 5v reference to it and vacuum.
azcamaro
Jun 11, 2009 10:45 AM
texas_outlaw93
Jan 9, 2007 07:12 PM
mdsbch
Oct 12, 2006 01:20 PM
Lee Willis
Nov 30, 2005 01:40 PM
jsteezy1290
Jul 28, 2005 12:28 AM
