MAF Main Power Relay
Please to anyone out there with an 86.... I have had MAF problems and had an ASE mechanic look at my car. In the process he changed the pigtails / plugs that go into both MAF relays (power and burnoff). Needless to say he didn't do it correctly... He put on the wrong pigtails and relays.Thankfully I kept the original pigtails!!! The burnoff relay pigtail had all colored wires connected and I was able to rewireand connect to propper pins in plug. Burnoff relay seems to be working fine now.
Big question here.....
Can anyone help me with the main power relay. I need to know what color wire goes to what pin (ie: a,b,c,d,e). I believe one is doubled.
I really appreciate if anyone can help here, if you can send a picture ofBOTH relay plugsshowing the wire orientation to the pinsthat would be even better.
Thanks!
Thanks!
Register and send a PM to 'Agent86', in digitalcorvettes. He has uploaded tons from his '86 shop manual.
Search his posts also; I put $$$ on he has posted wiring diagram for MAF.
