New to forum
Old Sep 6, 2019 | 11:24 AM
Tony Perme's Avatar
Question New to forum
84 crossfire starting issues.
Issue with the carbs flooding cylinders.
Car will start briefly when dry cylinders, then floods with injectors spraying fuel into port opening. (Flap closed)
Symptom when last driven was an acceleration of idle then a decline, pulsing.
Old Sep 24, 2019 | 03:14 PM
Welcome to the forum. Do the injectors spray fuel with the key on and engine off? Are there any codes set?
Old Sep 24, 2019 | 04:13 PM
Tony Perme's Avatar
Default Flooding
I retried observing the injectors as the car was started.
First injectors spray as ignition is turned on to start, its starts and then quits as the injectors over saturate the pistons.
So far as codes : i applied the shorting wire which gave me no results. Dash didn’t indicate any light changes.
any recommendations for OBD1 tester?
Old Sep 24, 2019 | 07:51 PM
Most auto parts stores like O'Reilly and AutoZone will scan for codes for free. I'm not sure injectors should be spraying with the key on and engine not running. Is that what you were saying it was doing?
Old Sep 27, 2019 | 09:36 AM
Tony Perme's Avatar
Default C4 flooding
What i meant when i said it continues to spray fuel , is that the starter is cranking and the engine seems to loose ignition spark? Just not understanding why I’m loosing run condition after the initial start.
ZR1clone
Feb 21, 2008 08:05 AM
fun4rx
Oct 12, 2007 11:12 PM
giostra
Jun 11, 2007 01:45 AM
red85
Nov 23, 2006 11:39 PM
KillaCam
Feb 20, 2006 09:43 AM
