checking fuel injectors
Old Nov 22, 2006 | 07:06 PM
red85's Avatar
Default checking fuel injectors
I just checked the resistance on my fuel injectors on my 85. They are all at 17 .5 ohms, give or take the small fluctations. Is this within an acceptable range?
Can I use my digital multimeter to check the power going to the injectors? How much power pulses through the conectors, and what setting should I be on to check them? What is the procedure?
Jay
Old Nov 23, 2006 | 04:10 AM
raisinbran's Avatar
Default RE: checking fuel injectors
yes that is acceptable, the key is that they are all relatively close together. You can check the volts, but that really wont do you any good. The injectors pulse so fast that the multimeter wont be able to refresh fast enough for you to see. The best thing you can get is a noid light to see the injectors pulsing. The ECM does not send more or less power to an injector to control fuel, it send the same amount of power to an injector, but contorls the length of time open and how often it opens. Hope that helps
Old Nov 23, 2006 | 09:54 AM
The fuel injectors have power on one side when key is on and are pulsed via ground by ECM which controls the lenght of ground time and time between pulses for calculated pulse width depending on TPS, ECT, O2, & MAP readings.
Old Nov 23, 2006 | 11:35 PM
red85's Avatar
Great information! I will get someone to turn the key while I move the noid from connector to connecter. Will do it tomorrow .
Thanks , Jay.
Old Nov 23, 2006 | 11:39 PM
red85's Avatar
So the pulse duration depends on the info gathered from the sensors.Thanks for the information.
Jay.
dean
Jan 9, 2007 12:55 AM
mercedes84black
Apr 22, 2006 11:03 AM
nosactivated
Apr 19, 2006 09:59 AM
KillaCam
Feb 25, 2006 10:47 AM
KillaCam
Feb 20, 2006 09:43 AM
