noisy 94
found most of the noise turns out the spindle nut was loose. The thing wouldn't move every time I jacked it up. Got mad and punched the tire while on a lift and the thing started wiggling. after all the attempts to get it to move now it wiggles an inch. Now I have to get a 56mm torx bit as A T55 is to small and a T60 is to big. found out the size from a local mechanic who can't find his. Well once I find the tool (local parts stores cant get it and the dealer is closed) I can finally fix this car. wonder if harbor freight or mac tools will have the oddball torx bit.
hoping It's bad gas this time as car sat for 4 months. Have had different hesitation/missing problems during the time I have had the car. all these things have been replaced from tome to time oxegen sensors, opti-spark and water pump, mass air sensor. No check engine light and no codes or info from scan tool. Anyone have any Ideas?
