Oil Temp Sensor, Where does it go?
Old 08-16-2008, 08:25 PM
ken93vette's Avatar
Default Oil Temp Sensor, Where does it go?
I took my 93 Vete LT1 engine out and sent the block (only) what I thought was bare (no heads) to be bored, pistons and rings. Big mistake, I did not take near enough pictures. Received a great looking block and they handed me a box back of all the misc parts. What a job figuring out where all the wire holders and pieces go.
After spending all day figuring most of it out, I have an extra wire and sensor on the driver's (left) side. I beleived it is the oil temp sensor. On the left side I have the knock sensor in, and oil level and the O2 located.
However, I can not find where this temp sensor would go? The builder put an alan bolt just above where you screw on the oil filter and below the large block ground bolt. Could this be a mistake or does this alan bold actualy hold in the oil filter base?
Also, I have what looks like an preasure fitting (brass bolt like with hole all the way through.
Please help, this is the last thing holding me back from getting the headers on because I certainly don't want to start working around them.
If any one could snap a pict of this area on a 92+ and post it would be a huge help.
Thanks
Old 08-16-2008, 09:12 PM
Default RE: Oil Temp Sensor, Where does it go?
Hey Ken, Got some info for you, on C4 vettes the engine oil temp. is left rear of engine above oil filter where that plug was installed. This brass compression fitting is it at the top left hand rear of the block?- that would be a possible mechanical oil pressure fitting.
imb1987
02-10-2008 06:23 AM
beauchampgl
09-08-2007 06:29 AM
MyC5WillEatYouAlive
05-15-2007 09:44 PM
chargedvette02
02-18-2007 01:44 AM
deepsquat
10-04-2006 02:45 AM
Quick Reply: Oil Temp Sensor, Where does it go?
