overheating..
ORIGINAL: toddg58
I just bought a 1993 and in traffic it overheats and starts running bacd, almost to the point it stalls. when not in traffic it starts to cool. it gets almost to 245 or so.....I have no check engine light or other indications..... can someone help??? I am new to vettes ....thanks.... Todd
ORIGINAL: larry00
Guy's on the hose blowing deal.
Blow from the fan side out or vice versa?
And feel free to askabout anything else that ain't clear.
ORIGINAL: toddg58
It also wants to run bad and die when it gets hot....... It is going back to the dealer tomorrow... any sugestions on the running bad also????
ORIGINAL: toddg58
is it a vacuum leak or maybe it might need new wires and plugs???? where should I start looking for the leak.....
Leaks develop in TPI's everywhere from the IAC at the throttle body, to the intake manifold/cylinder head junction. You might be able to find the leak with a can of startin fluid, sprayin' around where parts meet up, like the throttle body/ intake plenum, intake manifold/intake runners. The recommended way is with a propane can, UNlit, as described in the article:
https://www.corvetteforums.com/m_37283/tm.htm
page 22 (4 of 7)post.
You gotta raise the RPM's before the test, to get a steady RPM. THEN, you will find the leak. Read the whole article too.
ibelew is re-doin' his intake now... I'd like to know what he's got workin' now...
https://www.corvetteforums.com/m_37817/mpage_2/tm.htm (page 2)
