persitant codes
Old Aug 5, 2009 | 08:59 PM
dgm's Avatar
dgm
Default persitant codes
hi new member with just purchased 91 convertible.
been getting code 15 and 32, replaced egr solenoid and
connector. also thermostat and ect. Ive been a ford guy for
years and really like this car, but Im out of ideas please help
thanks dgm
Old Aug 7, 2009 | 04:13 PM
Viscount's Avatar
You'll have to use more detail. You replaced the EGR solenoid & connector.
Did the EGR valve check out ok or was that also replaced.
Are the codes your getting H...for history codes? or are they current?
Old Aug 26, 2009 | 06:25 AM
Satith's Avatar
Metal you are 100 WRONGIt is easily possible to have what baron wants with normal dash codes it just needs the /codes function to be edited within the codes.cs
Old Aug 26, 2009 | 10:29 AM
Bistinaws's Avatar
Ah, what do you mean "3, Both codes can be used 5 times per member, after that you will need to email us to renew your usage." so we can use it 5 times and then get more after that?
Ow, I best get posting
Thanks for offering these by the way
_________________
Auto boy
Old Sep 7, 2009 | 08:58 PM
darrell weber's Avatar
Post
I have a 93 corvette. It starts right up it will run 10seconds or 50 miles but when you shut it off it will not restart for at least 30 min.it kicks out a 28 code but I do not think the code has anything to do with the no start can any one help?
seapup0
Oct 25, 2006 05:56 PM
redvet
Aug 21, 2006 11:18 AM
Travis
May 3, 2006 03:02 PM
redvet
Dec 22, 2005 05:56 PM
lowmile89
Nov 24, 2005 01:45 AM
