Rag top/ deck lid problem
[:'(]I have a 1991 rag top to replace. I can here the solenoid click but the deck won't release.What would most likelybe the problem? Also isit possible to release the deck manually? Thanks
I have a 1987 Vette conv't which had the top replaced last year. Under my deck lid is a mechanicallever that releases the deck lid, and, in addition, I have a yellow button in my glove box which electrically releases the deck lid. Also, in addition to these, I have, in each of the two doors, a button which releases this deck lid. It appears to me that you should have at least one of these buttons, maybe two. Open one of your doors and look down the edge by the door latch and you may see a black(?) button; try it if you have one. I've often wondered why so many deck lid releases? Too many problems, maybe. I know the cable attached to the mechanical lever under the deck lid comes away a lot and has to be re-attached. Good luck; (hope I helped you.)
mypetu39
mypetu39
Thanks "mypetu39", I have all of the bells and whistles you mentioned also. I am confused about the mechanical lever. The lever in my vette releases the rag top from the deck. All of the other releases are electric and "I wish" should release the deck for top stowage. I hear the solenoid trying to work but it will not release. Am I missing a mechanical lever or does yours work the same way?
I neaver had your problem, but try this. Push down on the deck lid and at the same time have another person push one of the release buttons. One of your latches may have too much of a load on it to release.
[align=left] [/align]
Thanks Harry, I have tried that and with no success. I'm begining to think it may be a faulty ground.
Possiblythe connections got wet because the rear glass leaks. That's the reason for trying to open it in the begining, to replace the convertible top. Not much room toaccessthe solenoids
. You gotta love em when they are right, and hate em[:@]when they frustrate the @%)! out_ a_ you!! Thanks everyone, if you come up with anythingplease reach out. Happy vetteing!
ORIGINAL: hollywuuddh
TOPSPEED, this is exactly what I used to do before I replaced the cables attached to the mechanical lever in my '87 Vette; I had to turn the little knobby things under the hood, and it was hard on the fingers. Frustrated, I had the cables replaced and had the cable retainers actually welded to the lid; the lever works great now.
mypetu39
mypetu39
ORIGINAL: mypetu39
mypetu39
mypetu39
*scratches goatee* Welding the retainers to the lid... what a great idea! I'll use that, too, bro!
. You gotta love em when they are right, and hate em[:@]when they frustrate the @%)! out_ a_ you!! Thanks everyone, if you come up with anythingplease reach out. Happy vetteing!I tried to open the rear stowing hatch manually but the handle broke off on the drivers side. Can you get to the solenoids to release the latch if you can't get the lid open?
I have the same problem in my 1994 Corvette. There is evidence of significant water intrusion and I believe that the electrical connections are corroded.
