RATTLE
Old Jan 17, 2009 | 06:50 AM
TEXAS HARRY's Avatar
Default RATTLE
My 1993 C4 has a rattle-thud type sound in the right rear when going over bumpy road.I checked the exhaust and anything else that could be loose but no luck?
Old Jan 18, 2009 | 12:01 AM
Default RE: RATTLE
bad shock??
Old Feb 2, 2009 | 06:51 AM
larry00's Avatar
Sounds like broke shock .
Old Feb 12, 2009 | 05:34 AM
RudeDog's Avatar
Exhaust system or shock gotta be my guess too. Good luck.
Old Mar 6, 2009 | 03:08 PM
95C4's Avatar
Default Rattle Thud
On my '95 it was the sway bar end links. Somewhat of a pain to replace (left the sway bar under the car) but it got rid of that noise and many other bothersome clanks, squeaks, rattles, etc. Diagnosed by raising the frame jacking point on a jack stand then used a floor jack to slowly raise and lower the wheel assembly. The slack was apparent from the motion even though the bushings are not visible when assembled.
I used a bolt, washers, nuts and appropriate sockets for spacers to make a 'hand puller' to extract the old bushings and press in the new ones (with lots of silicone lube). Cheap fix, under $20 including the big bushings that hold the sway bar to the frame.
Genocide
Dec 28, 2006 06:37 AM
rjensen
Aug 3, 2006 11:44 PM
Sullyvette48
Mar 26, 2006 01:25 AM
Red Z06
Dec 23, 2005 11:04 PM
hobbydays
Nov 20, 2005 02:49 AM
