Re: ABS wheel Sensors 1988
Old Sep 20, 2006 | 10:17 PM
fille9's Avatar
Default Re: ABS wheel Sensors 1988
Are the wheel sensors on my 88 built into the wheel Hub?? If so, How can I clean them?? My system is down and I would like to clean the wheel sensors as first step to correcting my problem. Is this possiable???
Old Sep 20, 2006 | 10:26 PM
Default RE: Re: ABS wheel Sensors 1988
The ABS wheel speed sensors are magnets that read magnetic field interruptions by a wheel that looks like a gear on the back side of the wheel bearing hub assembly. Just pull the retaining bolt out of the sensor and gently rotate it back and forth so as to not damage the wiring and pull it out. The you can clean them. [8D]
Venture Capital
Nov 16, 2009 10:00 AM
Larry Brumbaugh
Apr 10, 2008 07:35 PM
CEILIA
Aug 21, 2005 02:05 AM
CEILIA
Aug 20, 2005 04:07 PM
CEILIA
Aug 20, 2005 03:49 PM
