Shift knob removal, automatic
Old Jun 4, 2006 | 01:14 AM
eewiz's Avatar
Default Shift **** removal, automatic
How do you get the shift **** off? I popped out the button, and removed the retainer ring. The **** wont BUDGE! Is there a set screw? No mention in the GM service manual. Automatic. Thanks for advice.
96 LT1 yellow.
Old Jun 5, 2006 | 09:24 AM
Default RE: Shift **** removal, automatic
That's how mine comes off. Probably lots of years and being stuck to the shifter. May have to get physical with it.
Old Jun 20, 2006 | 10:33 AM
Larry Brumbaugh's Avatar
Saw your post this morning. Unfortunately saw my dog heading for the door as well he's gotta go and I've got to get to work. Info is in the manual. When I get home tonite I'll sap you back.
Larry
Old Jun 20, 2006 | 10:15 PM
Not sure if the 96 is the same but my 93 GM Service manual describes the following:
Remove shifter button by prying up, shift button retainer, snap ring, and shift ****. no mention of set screw w/ the automatic just the manual tranny. I took mine off a while back to replace the light (position indicator) and just strongarmed it loose after a little wd 40 the snap ring attaches around the control lever. Hope this helps.
Larry
Old Dec 22, 2006 | 04:32 PM
JoeVetteman's Avatar
Hi!! You'll need a set of snap ring pliers and then just enjoy yourself pulling it out! I did it to my '96 to put one of those neat-looking "carbon fiber look" shift *****.But before I put the new one on,I put a key ring with a little logo that I got at the Air and Space Museum.It reads, "REMOVE BEFORE FLIGHT"!!!!!
hsean
Aug 25, 2008 07:40 PM
PAY2PLAY
May 2, 2007 10:36 AM
Dave01
Oct 26, 2006 02:16 PM
slw98vette
Apr 15, 2006 03:05 AM
hobbydays
Nov 20, 2005 02:49 AM
