starter problems
Old Jun 2, 2007 | 06:59 PM
Alans 94 vette's Avatar
Default starter problems
I bought my first vette about 3 weeks ago. Its a 94 6 speed car . Well about 2 weeks ago the starter was acting up. When i would attempt to start it the starter would only click. I would try this 3 or 4 times and it would start. This morningI started the car up to pull it out of the garage and when I turned the switch off the starter was still trying to start the car .I turned the switch back on and the car started back up.It took 3 or 4 times for the starter to cut off .Anyone that has had this and could help me I would appreciate.
Old Jun 2, 2007 | 11:14 PM
Default RE: starter problems
The contacter plates in your starter solenoid are burnt together causing the starter to act like the key is on more than likely. If you don't have power to the solenoid with the key off, then it's time to replace the starter.
Old Jun 2, 2007 | 11:59 PM
Thanks for your help.I'll order me a starter on Monday.Is the starter hard to remove?
Old Jun 3, 2007 | 07:41 AM
Well, it isn't the easiest task, but certainly not the worst. Bit more of a pain on the ground.
Old Jun 3, 2007 | 07:12 PM
alive69's Avatar
Its easier than the sparkplugs. Be sure to unhook the battery cables first!! Sure sounds like a solonoid tho. j
zzz06r
Jun 4, 2009 11:07 AM
Alans 94 vette
Jun 23, 2007 08:51 PM
Carmen
Mar 14, 2006 02:26 PM
Lee Willis
Nov 10, 2005 09:14 AM
jeepin45
Aug 23, 2005 12:44 AM
