Starter giving problems
Old Jun 2, 2007 | 06:32 PM
Alans 94 vette's Avatar
Default Starter giving problems
I purchased a 94 6 speed vette about three weeks ago. I got the car home and maybe a week later the starter started acting up .Sometimes it will start right up and other times it will click. I will attempt to start it 3 or 4 times and it will start.This morning I started it and pulled it out of the garage and when I turned off the switch the starter was still turning the motor like I was trying to start it. I attempted to cut the car off 4 times and it finally cut off. I was wondering if anyone has had this problems and can help me .
Old Jun 23, 2007 | 04:02 PM
Default RE: Starter giving problems
This sounds like a possible ignition switch prob.
Old Jun 23, 2007 | 04:59 PM
ORIGINAL: C3 Starship
I've heard of this before.
Doesn't the solenoid have a mechanical switch in it, which carries the 12 volt through the solenoid to the starter? Seems I've heard something like this, where the solenoid's internal switch sticks in the 'energized' position, and continues to engage the flywheel (and sometimes it sticks in the 'open' position, and you get a 'no start')...
I don't think all the battery's amperage goes through the ignition switch - just an amp or two to physically close the solenoid's circuit. Right?
Old Jun 23, 2007 | 05:44 PM
You're right cwb. Although, sometimes the ignition switch may continue to provide power to the solinoid. I think you may be on the right track though, the solinoid may be bad.
Old Jun 23, 2007 | 08:51 PM
ORIGINAL: Alans 94 vette
So as you backed the car out, could you tell that the starter was still engaging the flywheel the entire time the motor was running?
If it's the ignition switch itself, like C3 said, it could be a matter of powder graphite lube (or petroleum lube). If a solenoid problem, it's integral with the starter assembly - I've never done that type of solenoid replacement (but that might ALSO be a lube fix).
zzz06r
Jun 4, 2009 11:07 AM
Alans 94 vette
Jun 3, 2007 07:12 PM
Carmen
Mar 14, 2006 02:26 PM
Lee Willis
Nov 10, 2005 09:14 AM
jeepin45
Aug 23, 2005 12:44 AM
