still more starting problems
Old Sep 26, 2007 | 08:07 AM
95trplblkandtan's Avatar
Default still more starting problems
whats up guys, id posted this issue a while ago and had no response, but i thought i would give it a try again. my 95 just doesnt like starting the first time i turn the key. ill turn the key and all i hear is a click, i do it a few more times and the car starts. sometimes i only turn the key a couple of times and then it starts, other times i turn the key 15 to 20 times and then it starts. So far i havent been stranded anywhere, it has always started eventually (knock on wood). any suggestions, ive already replaced the battery, and the bolts that hold on the bat. cables. ??????
Old Sep 26, 2007 | 08:24 AM
rshiver's Avatar
Default RE: still more starting problems
Sound like a bad starter to me,or a bad connection at the starter solenoid.
The clicking you're hearing is probably thesolenoid.
Ifit were me, I would replaceboth the starter and the solenoid while I had it out.
Checkthe connection at the starter first.
Old Sep 26, 2007 | 09:32 AM
red90vettesc's Avatar
I had the same exact thing happen to my car. I beleive both of our cars use a gear reduction starter. I my case it did turn out to be the starter, because a gear in the reduction assembly cracked. I could turn the key, hear a small click and that would be it. I would turn it several more times and it finally would start. I would have your starter rebuilt. I did mine and it hasbeen fine ever since. I hope your starter is easier to get out then mine was, it was a rean PIA. Good luck.
Old Sep 26, 2007 | 09:46 AM
alright, thanks man, i will have to check that out when i get back home today.
avgjoe
Nov 30, 2008 10:18 PM
rshiver
Oct 17, 2007 07:03 PM
lbelew
Aug 6, 2007 09:08 PM
all84vette
Mar 17, 2007 01:30 AM
Fuzzy74
Jun 15, 2006 01:10 AM
