tail light question
Old Jun 27, 2006 | 01:44 PM
mercedes84black's Avatar
Default tail light question
on my 1985 the tail lights went out so i checked the fuse and it was blown. i replaced with correct one and blew again went a size larger blew again. as soon as i pull on the light switch they immediately blow, could i need a light switch replacement
Old Jun 27, 2006 | 09:21 PM
Default RE: tail light question
please, really need help on this one, as i can't drive at night. if no answer could someone direct me to a site that may have the answer. thanx in advance
Old Jun 28, 2006 | 09:56 AM
Doubt if the switch is bad. Need to check for a short to ground on the light circuit front and back lights. Do you have an ohm meter? Start unplugging lights and wiring harness's first to try and isolate the problem. Use your ohm meter on the load side of the fuse to check for the short instead of using a bunch of fuses.
Power$elling
Jan 22, 2007 04:31 PM
Power$elling
Jan 15, 2007 04:26 PM
POLO GREEN 90
Nov 26, 2006 11:23 AM
Kyle93
Mar 20, 2006 06:58 PM
Wrangler47
Mar 3, 2006 09:33 AM
