TPI maf system V TPI SPEED DENSITY
Old Nov 21, 2006 | 11:24 PM
ssgcarlson's Avatar
Default TPI maf system V TPI SPEED DENSITY
Hello,
Has anyone change a '87 vett from a MAF system to a Speed Density system, by adding a MAP sensor, Accel power process for a GM computer controlled engine and the use of CALMAP calibration software.
[IMG]local://upfiles/3690/444AD38EBFAF45C5B7243AB86E3D6F6D.jpg[/IMG]
Old Nov 22, 2006 | 11:17 AM
Black86vette's Avatar
Default RE: TPI maf system V TPI SPEED DENSITY
Why are you changing?
Old Nov 22, 2006 | 11:31 AM
ssgcarlson's Avatar
The MAF system is really restrictive with the maf sensor and then i can add a ram air system. with the CALMAP software you can hook up a laptop and change fuel and time curves
Old Nov 22, 2006 | 12:08 PM
PM mech. He would know. If you want to go the cheap route, descreen your maf and grind down the heat sink fins. But if your set on that, then go for it. Good luck.
Old Nov 23, 2006 | 04:56 AM
raisinbran's Avatar
Im not sure if the pros outweigh the cons. The reason they changed back to MAF was because the MAP system isnt as accurate in measuring air coming in. You can get an adjustable MAF, or get different software to change the tables.
Old Nov 23, 2006 | 09:47 AM
Later years, GM used speed density in production vehicles and it works fine. When they brought it back, they re-engineered the MAF hot wire sensor for more durability and accuracy. We have changed out a lot of the older MAF's, but very few of the newer ones. Even Ford tried the speed density setup along with Chrysler in early 90's. You shouldn't have any problems with it, just as long as you got the proper calibration for it.
1989 BLOWNCONV VETTE
Jun 17, 2008 06:33 AM
rwolak
Dec 9, 2006 12:29 AM
mypetu39
Sep 4, 2006 12:37 AM
Tyler
May 19, 2006 03:24 PM
GMRULZ
Jan 26, 2006 10:43 PM
