transmission cooling line leak
Old Oct 18, 2007 | 08:29 PM
Ric's Avatar
Ric
Default transmission cooling line leak
I have a trans leak so i have it up to investigate and this is what i have found. The cooler line has bin disconnected and this round thing about the size of a large fuel filter was installed. It has rubber tubing and double hose clamps on it, this is my leak. I am guessing it is some type filter that was installed after some sort of transmission work or trans cooler work. I would like to remove this thing. anybody no for shore what it is? and your thoughts about removing it?
Thanks Ric W
Old Oct 18, 2007 | 09:07 PM
Default RE: transmission cooling line leak
ORIGINAL: Ric
Thanks Ric W
Whatsa' chance of gettin' a pic of this thing?
I'm gonna' try to find a tranny cooler line disconnect point tomorrow, to purge the fluid- I'm doin' a filter/fluid change right now. You think someone cut the line on yers, just for that reason? And then re-connected with a filter?
Old Oct 18, 2007 | 09:38 PM
Ric's Avatar
Ric
hi cwb
I don't think it was installed instead of trans fluid change i think it might be something installed to clean up shavings from previous. trans work or cooler work. I just don't know. It is not stock and is my leak. Thought I might get lucky and find a transmission mechanic out there. sorry cwb I'm a little computer challenged as far as the picture goes. I would like to remove itthough, but I would like to find out what it was for. If i don't get any replies I will probably ask at a transmission shop.
thanks for taking the time. Ill give this thread some time. and then ask around ill let you know what I find.
Ric W.
Old Oct 18, 2007 | 10:24 PM
ORIGINAL: Ric
hi cwb
Ric W.
I'm doin' mine as we speak.
https://www.corvetteforums.com/m_44971/tm.htm
If I see somethin' tomorrow, I'll sound off. Even if I don't see somthin' I'll sound off!!!!!!!!!
Alberto Martinez
Apr 14, 2014 07:20 PM
avp0713
Jul 23, 2008 04:52 AM
pookie16
Aug 12, 2007 07:59 PM
72and86
Jul 15, 2006 01:04 AM
rkm
Nov 28, 2005 08:47 PM
