Vacuum hose Replacement
Old Apr 24, 2008 | 12:57 AM
85vette80821's Avatar
Default Vacuum hose Replacement
Im just wondering what size rubber vacuum hose should I use to replace the fragile plastic ones that run under the plenum and to the EGR valve? Ive read in a post that they are prone to break and cause vacuum leaks so since Ill have the plenum and intake manifold off, I figure ill replace them with rubber ones. The local checkers has 5/32" and 7/32" sizes in stock. Thanks.
Old Apr 25, 2008 | 10:10 PM
Default RE: Vacuum hose Replacement
Since you're replacin' hoses (a very GOOD thing to do) just cut small pieces off the end and take them to the store. Remember the piece that's been stretched over a vacuum nipple might be harder to match too.
DrJ
May 18, 2008 02:10 AM
81GAVette
Technical Diagram Help
Oct 17, 2006 07:18 PM
wrwalke
Sep 11, 2006 02:12 PM
drdenny
Aug 14, 2006 02:01 AM
silver78
Mar 10, 2006 12:50 AM
