What Octane Gas?
Old Sep 22, 2006 | 09:24 AM
  #11
mypetu39's Avatar
Default RE: What Octane Gas?
Up here in Ontario, Canada, we have Sunoco 94 and it rings out to an actual 96 octane rating more for the Winter months than anything else. Burns extremely clean.
mypetu39
Old Dec 22, 2006 | 12:14 PM
  #12
JoeVetteman's Avatar
Hello!! I think you should use 93,or higher,if you can find it.I believe the Vette has always required premium,but I'm not sure.But I would still use high-test.Just to be safe,you know??
Old Dec 22, 2006 | 01:31 PM
  #13
raisinbran's Avatar
The owner's manual calls for 91 octane. the higher the octane, the slower the gasoline burns. higher octane does help reduce knock, but after a certain point it will hurt performance unless your engine is designed for it.
Old Dec 23, 2006 | 02:09 PM
  #14
92VETTE's Avatar
i run 93 in mine, and run a fuel system cleaner in every 4th tank...
Old Dec 23, 2006 | 06:46 PM
  #15
BluBeaSSt's Avatar
91-93 depending on your state, I tried 87 ONCE in my LT1 and she hated it
Gotta pay to play
Old Dec 23, 2006 | 06:49 PM
  #16
BluBeaSSt's Avatar
ORIGINAL: Togarider
I read an article many years ago that you can run the lowest Octane in your car as long as it doesn't knock. That you are paying to much for high Octane if you don't need it.
But I have also heard just the other day that the new cars with computers will adjust the car to what ever Octane you put in and that it wasn't good to change your Octane back and forth because this would screwup your computer.
I would say in the long run that you own a Corvette for the preformance of the car and that it will perform best with High Octane gasoline (93).
All your computer will do is feel the pinging in the knock sensor then retard the hell out of the timing and you will lose hp. and no going back and forth wont screw up your PCM, all it is is a brain, it takes and recives info. you will never find the same rating any gas unless you go to the same station everytime you fill up.
Hope that makes sence
Old Dec 23, 2006 | 10:44 PM
  #17
Crash's Avatar
Tried the low octain fuel in my 86 vert,when I first got it, the amount of pinging under the hood was crazy . I use the throttle pretty heavy and it would rattle like a diesel (the timing would retard but go back to a normal timing advance when not under load , mash the throttle again and the same thing would happen ) So I just use high octain only now and no more pinging.
Cheers Rob
Old Dec 24, 2006 | 06:37 AM
  #18
raisinbran's Avatar
I used to put in the V-power gas not only cause it was 93 octane, but also because its supposed to have all those extra detergents. The engine ran very smooth, but there seemed to be slightly less throttle respone. My car is happy on 89. I think ive got my timing at 8.5 BTDC
chuck
Mar 7, 2010 05:42 PM
82_vette_600hp
Jul 15, 2007 08:00 PM
grabie
Mar 15, 2006 04:00 AM
Vette4LIFE
Mar 11, 2006 11:11 PM
blbcklt1_tb
Jul 31, 2005 03:11 AM
