Window wont roll down
Old Aug 2, 2007 | 08:16 PM
Thunder's Avatar
Default Window wont roll down
Hi . newbie here I just got my first Vette,A Red 92 I got it home and the drivers window wont go down. passenger side is fine. anyone got any idea's?
Old Aug 2, 2007 | 08:41 PM
Viscount's Avatar
Default RE: Window wont roll down
Start by checking power source & then the switch. Has a 30A circuit breaker in the I/P fuse block.
If the other window is working it's probably the switch?
Old Aug 2, 2007 | 08:49 PM
Thunder's Avatar
Thanks, I will check it this weekend
Old Aug 3, 2007 | 07:03 AM
LeesVette's Avatar
Could be a broken window ribbon.
Old Aug 3, 2007 | 11:58 AM
ORIGINAL: Thunder
It probably will take 5 minutes to check it like vis said (which is the best advice). Most folks would deploy the Fully Automatic Assault Wallet[sm=shootshoot.gif][sm=violent053.gif], and buy a newpiece of glass, then a new door ("Yipee, It's fixed! The door was bad."), ECM, etc., ...
If you hear a clickin' sound, the drive gearin' is worn like lee said. But if you DON'T, itCOULDstill be the drive...
Old Aug 3, 2007 | 02:14 PM
The window regulator in yours is all metal gears. More than likely, you have a bad motor or switch.
Old Aug 3, 2007 | 04:51 PM
Eggster's Avatar
It could be electrical. My passenger window didn't work for 2 weeks, then started working again. I discovered since the weather stripping is bad on that side (at the time), it was leaking water inside the door and possibly causing a short. I'm guessing after the water evaporated the short was no longer there and presto: I haven't had problems since.
Either that, or my car carries the uncanny ability to regenerate itself .
Nice year and color of vette BTW.Mine's a twin, sort of.
Old Aug 4, 2007 | 10:09 PM
Superdzzz's Avatar
[sm=welcomesign.gif]
If you can rule out the switch, then it is more than likely the motor on yours.[:@]
A dealership and/or repair shop will try to tap you for the whole "shebang" motor and armature assembly.
However, all you have to do on a C4 is drill out the rivets on the old motor and order a new motor from one of the MANY online sites. $70 versus $400.
Buy rivets and tool, $30 at Home Depot.
Find somebody patient and competent enough to deal with a Vette door
Or ask and I have the procedures for unassembly and reassembly for the window motor[8D] With pictures[8D]
David[sm=icon_cheers.gif]
Old Aug 5, 2007 | 10:46 AM
beauchampgl's Avatar
When we first got our 93 the passenger side window wouldn't roll down. The fuse was OK. Got some tuner/contact cleaner at Radio Shack and gave the switch a shot or two. Worked fine after that. Hope your fixis that simple.
Old Aug 5, 2007 | 01:20 PM
OOOOOOOOOOKKKAAAAAAAAAAAAYYYYYYYYYYYYYYYY......... ..
What's up with the eye????????????????????????????????????[sm=smiley8.gif]
