z51 info
Hello...not sure if the vin gives that info,but depending on the year of your car,look at the sticker on the driver's door where it specifies the tire sizes installed at the factory.If it says that all four are 275's then it should be a Z51 car....if it says 255's front and 285's rear,then it's either a Z52 car or a base-suspension car,I do believe.Also,check your steering,lock to lock.2 and 1/4 turns=Z51...anything more=Z52 or base-suspension car.Hope this helps...Joe
Hey Gang,
Unfortunately our forum here is dying and the powers that be do not seem to care, if they did they would have shut me up weeks ago. Our forum is over run with ads for sex, drugs and more. There are also hardly any users here any more. Try visiting ********.com for an informative and lively Corvette Website!
Come on, what have you got to lose?
ok thanks,i 4got 2 add it says 255's front and rear,but it only turns 2 full turns from lock 2 lock.so im not sure also has bose sound system if that means anything,and fuel pump at the top of gas lid.and aluminum angle plug heads(tuned port).thanks
