ZR1 type wheels for C4
im told there are ZR1 type wheels for regular C4 vets that can be purchased. apperently they are made with an offset so they will fit a regular C4 while still putting as much rubber down as authentic ZR1 wheels.
can anyone elaborate?
what i can tell you is that 84-87 offset for 9.5" wheels is 38mm. 88-96 is 56mm
zr1 rims will fit 84-87 with no adjustments, for the zr1 offset is the same. so maybe someone can do the calculations and figure out what you will need for the 92-93 year
Hello,my friend.As far as I remember,the ZR-1 wheels will fit the '84 to '88 Vette as long as you use a spacer.For the '89 to '96,they will bolt right in.I know,I have the Grand Sport wheels on my '96 and they look great!And the rears are the big '11s with 315 size tires.Hope this helps you.
