1999 A/C Blwing Warm Driver Cold Passenger?
I have the same problem on my passenger side. Most likely a bad actuator. Run the codes on the DIC and see if you get the actuator out of range code. I was told that disconnecting the battery for a few minutes might reset it. It didn't work in my case but you might give it a try.
Good luck
Good luck
corvette king
Nov 21, 2006 11:03 PM
