1999 A/C Blwing Warm Driver Cold Passenger?
Old Sep 3, 2009 | 11:39 PM
charliebebo's Avatar
Default 1999 A/C Blwing Warm Driver Cold Passenger?
My A/C blows cold on passenger side warm on driver. Dual climate control. Any ideas Thanks
Old Sep 5, 2009 | 04:03 PM
sodian's Avatar
I have the same problem on my passenger side. Most likely a bad actuator. Run the codes on the DIC and see if you get the actuator out of range code. I was told that disconnecting the battery for a few minutes might reset it. It didn't work in my case but you might give it a try.
Good luck
Old Sep 5, 2009 | 06:32 PM
Dave01's Avatar
Check to see if refrigerant is low. I've heard that this condition can result in cold air on one side only.
amvette
May 3, 2007 07:53 PM
Callipjm
Mar 6, 2007 09:42 AM
corvette king
Nov 21, 2006 11:03 PM
06 Vette
Jan 23, 2006 10:24 PM
Richvette
Oct 5, 2005 12:39 AM
