Air pump?
Old Jun 28, 2006 | 09:59 AM
kruser's Avatar
Default Air pump?
Ok, I am getting a consistent P0410 error code, which indicates "Air system". Anyone have similar problems and what did you do to fix it? Also, just exactly where is the air
pump on a 1998 corvette coupe?
Old Jun 28, 2006 | 11:51 PM
Default RE: Air pump?
On most Corvettes, the "air pump" is the air injection pump for emission controls, and I think it is electricly operated and controlled by a relay. More than likely, either your pump is bad or the relay or some fused control. Attached is a wiring diagram for the air injection pump. Check the air pump fuse in your underhood fuse panel. Set your printer to landscape to print it.[8D]
vaelon
Aug 11, 2015 09:05 PM
Blackz51
Aug 6, 2007 04:04 PM
tg
Dec 17, 2006 01:07 PM
jmtrotzie
Oct 31, 2006 12:50 PM
korvette4u
Aug 6, 2005 01:15 PM
