c-5 engine problem
Old Nov 11, 2012 | 02:33 PM
tbotnen's Avatar
Default c-5 engine problem
while driving home my check engine lite came . i shut the motor down restarted and the check engine lite continued to flash. i drove the car home it was smoking bnadly. when i went to the rear of the car there was a very heavy gas smell. suggestion? the car was running fine before the incident. the car has 80,000 mi's and is holding good oil pressure and not overheating.
Old Nov 12, 2012 | 06:08 PM
Dave01's Avatar
The first thing I would do is check for disconnected hoses (especially vacuum hoses/lines), spark plug wires, connections at the airbridge/accordian to throttle body, air bridge to Mass Air Flow sensor, and anything else that is visually not right. Chances are that you'll find the culprit.
Old Nov 13, 2012 | 03:42 PM
tbotnen's Avatar
Default c-5 engine problems
problem solved... found #1 plug was dead...replaced now everything is fine.
Old Nov 13, 2012 | 10:28 PM
Dave01's Avatar
Thumbs up
Great! That was within the second tier of inspections I was going to recommend.
scotth48
Oct 17, 2008 02:35 PM
scotth48
Sep 23, 2008 06:25 PM
RickStehr
Jul 30, 2007 11:29 PM
RickStehr
Jul 9, 2007 11:58 AM
Maytes
Jun 22, 2007 08:18 AM
