C5 door lock switch
C5 door lock switch L.H. side won't work
My LH door lock botton, when pressed, will unlock both doors. but, does not work to lock either door when pressed. All other controls on the LH door, (window and mirror switches), work fine. All switches and buttons on the RH door work fine. The RH door lock button when pressed, will lock both doors. The remote will lock or unlock both doors. How can I tell if the problem is in the LH switch or in the black control box. I don't want to replace one only to find the problem is with the other. Both are expensive parts to replace. Any help or advice would be appreciated.Please don't tell me to go to a dealer. I can't afford it. Also, is part replacement something I can do myself?
Chuck
Chuck
Last edited by chuck; Feb 17, 2009 at 07:20 AM. Reason: additional question and info
TripleBlackC5
Oct 15, 2007 07:14 PM
