C5 door lock switch
Old Feb 16, 2009 | 01:40 PM
chuck's Avatar
Default C5 door lock switch
C5 door lock switch L.H. side won't work
My LH door lock botton, when pressed, will unlock both doors. but, does not work to lock either door when pressed. All other controls on the LH door, (window and mirror switches), work fine. All switches and buttons on the RH door work fine. The RH door lock button when pressed, will lock both doors. The remote will lock or unlock both doors. How can I tell if the problem is in the LH switch or in the black control box. I don't want to replace one only to find the problem is with the other. Both are expensive parts to replace. Any help or advice would be appreciated.Please don't tell me to go to a dealer. I can't afford it. Also, is part replacement something I can do myself?
Chuck
Last edited by chuck; Feb 17, 2009 at 07:20 AM. Reason: additional question and info
Old Feb 18, 2009 | 10:47 PM
Dave01's Avatar
Old Mar 18, 2009 | 12:56 PM
chuck's Avatar
Dave 01, thanks a million. I replaced the lock switch assm and the window regulator thanks to your input.
Chuck
Old Mar 20, 2009 | 10:47 PM
Dave01's Avatar
I'm glad I could point you in the right direction, Chuck!
Dave
chuck
Feb 15, 2009 07:40 PM
Baudier
Jun 19, 2008 10:27 PM
TripleBlackC5
Oct 15, 2007 07:14 PM
bertsbassbox
Mar 27, 2006 05:32 PM
jadrfld
Feb 25, 2006 06:17 PM
